rjohns75
Feb 15, 2023Aspirant
Netgear Nighthhawk and Blink Camera local storage issue
I was having trouble getting the Blink Camera local storage feature to work on my Nighthawk network. All of the Blink features worked except for the ability to locally store recorded video clips to t...
- Mar 19, 2024
I only thought to update this when I noticed the sync module device type was set to camera after I started troubleshooting. Hope this works for others.
Verity7
Aug 01, 2023Aspirant
Hi All,
Just wanted to share my experience... it turns out my secondary router being set as wireless access point was preventing Blink sync mod from connecting. Kept getting error about network password, blah,blah,blah... I knew that was false.
Since my Blink was not connected to that router, I hadn't really thought if that configuration as being the culprit. After being unsuccessful with just about every suggestion here, I started backtracking steps. Once I reverted to standard router setting (not an access point), I was able to reconnect Blink sync mod.
I hope it helps someone!
Verity7
Verity7
michaelkenward
Aug 01, 2023Guru - Experienced User
Nice detective work Sherlock.
A couple of questions:
- was the AP mode device running with a different SSID/password from the main router?
- when (if) you put the thing back to AP, did the Blink stay connected?
