keithblawrence
Sep 07, 2020Follower
netgear r6250 name seen by windows for wired internet connection
I am seeing different names appearing on Windows 10 for the Netgear router name offering wired internet. On 1 PC it is showing as NETGEAR32 and on the other NETGEAR 24 3 Cannot see how this is chang...
Sep 07, 2020Guru - Experienced User
Its windows that doing that under its active network profile. Not netgear.
You can change them but you'd need to modify your registry (which I wouldn't recommend if you're not familar with it).
