johnsmith321
Jul 30, 2022Aspirant
Netgear r6700ax - guest network can access my ISP router and other computers. Chrome cast not workin
https://i.imgur.com/mHe4kQu.png I have my ISP router 192.168.50.1 which provides internet. My TV (192.168.50.20) PC1 (192.168.50.10) are connected to it. I bought a Netgear r6700ax; I conne...
michaelkenward
Jul 31, 2022Guru - Experienced User
johnsmith321 wrote:
I bought a Netgear r6700ax; I connected the wan port to the ISP router.
It seems to create its own subnet 10.0.0.1.
That is a classic sign of "double NAT" syndrome. It happens when pile router on router.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
That has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
- johnsmith321Jul 31, 2022Aspirant
I tried it. If I use the netgear router as AP, it works fine except guest network cannot connect to the internet...I am guessing it is because devices on the guest network is not allowed to even communicate with the ISP router for internet. (I was advised to use the wan port and use the netgear router as a router but I am getting the issues described in my first post)
