stockbucks
Jun 17, 2024Aspirant
Netgear R6700AX AX1800 Router won't connect wirelessly...ENET working fine thru Router
R6700AX firmware ver: 1.0.15.146......Win10 Pro H22022...Centurylink modem automatically updates firmware! My INET thru ENET in router thru Centurylink C4000LZ in Transparent Bridge Mode (VPI/VCI...
stockbucks
Yes, all 4 lights are Green...Thx
Kitsap
Jun 17, 2024Master
stockbucks wrote:Yes, all 4 lights are Green...Thx
Have you logged in to the user interface and renamed the Wi-Fi SSID, or did you leave it the same as printed on the label on the back?
Did you configure the router using the mobile application or use a web browser through a computer?
Computer would be best. Within the user interface there is a place to turn the Wi-Fi on/off. You should toggle it on/off a couple of times and reboot your router.
Keep in mind the router broadcasts the Wi-Fi signal, the client devices do the connecting.
- stockbucksJun 17, 2024Aspirant
1-left everything the same as label
2-mobile ap cud not find the router...web interface wud not connect w 192.168.1.1
3-cud not get to the Wifi on/off setting in the router...rebooted the router at least 5-6 times
4-understand Wifi broadcasts...but no device (listed earlier) cud find the router...THUS...
I've about decided the Wifi radio is defective... what do u think?
NOTE: I've been dealing w PCs since 1986, keep in mind the IBM PC-AT came out in 1984...lol...I've never tried this hard to get something to work in over 15 years (I'm 72 now)...I thot I had just lost my touch, but I took an older R6100 Router I previously had in service years ago and made it work without changing anything on the Centurylink modem :).
Wud welcome your insight, Thx again and God Bless!
- KitsapJun 18, 2024Master
stockbucks wrote:1-left everything the same as label
There is a very real possibility the Wi-Fi radio on your router is defective.
Stay away from the mobile application. Nothing but problems will result if you don't.
The world of Wi-Fi and home networking has evolved significantly since 1986 and the world wide audience of bad actors has multiplied many times.
I passed through 72 some time ago. Please turn on your spell checker.
Your first priority should be to get access to the router user interface using a windows computer and Ethernet cable. Does you windows computer have an Ethernet port?
- stockbucksJun 18, 2024Aspirant
LOL...Texas slang has its own spellchecker LOL...You being past 72 gives me hopeđ...
Yes on the ENET port and cable...tried many times to access the modem thru browser interface...only was able to do it once at the beginning using 192.168.1.1...set up custom SSIDs for both bands etc...then when I saved the info into the router, I never was able to "see" the router on any devices (details 1st msg)...so I did a hard reset on router and started over and still cud not see the router on any devices...so I reached out to the EXPERTS...and here we are.
I appreciate u much and God Bless đ
