stockbucks
Jun 17, 2024Aspirant
Netgear R6700AX AX1800 Router won't connect wirelessly...ENET working fine thru Router
R6700AX firmware ver: 1.0.15.146......Win10 Pro H22022...Centurylink modem automatically updates firmware! My INET thru ENET in router thru Centurylink C4000LZ in Transparent Bridge Mode (VPI/VCI...
michaelkenward
Jun 18, 2024Guru - Experienced User
stockbucks wrote:
My INET thru ENET in router thru Centurylink C4000LZ in Transparent Bridge Mode (VPI/VCI = Untagged) working great...
Can you say a bit more about the "bridge mode"?
There is usually more to it that a simple tweak. For example, a lot of people turn up here thinking that turning off the wifi does the trick. No.
Then there is the problem that bridge mode means different things on different contexts.
Throw in how different modem/routers work and you enter a minefield.
In this case, how does "VPI/VCI = Untagged" fit into the bigger picture?
- stockbucksJun 18, 2024Aspirant
Sorry about the quality, thx 🙂
- michaelkenwardJun 18, 2024Guru - Experienced User
I have several years on both of you, but I have worked out how to get screen grabs using "Alt + PrintScreen".
Sadly, while I can just about read that picture, it isn't clear to me that you have the correct settings. Have you sought advice from your ISP?
It looks like this modem/router has caused other users problems with bridge mode:
Centurylink C4000LZ in Transparent Bridge Mode - Google Search
There are several promising links there. But it does boil down to a problem with the modem/router rather than the R6700AX
See this:
C4000 Modem Setup | CenturyLink
If that is the modem/router you own, I wonder why you want to dredge up the R6700AX. The CenturyLink books looks like it is younger and more capable that the Netgear router.
If it is a wifi range thing, you could use the Netgear in Access Point mode.
