DearGeo
Dec 15, 2021Tutor
NETGEAR RAX 200 / Orbi
How can I connect these two router together so I can extend my WIFI around my house. I get some dead spots that I need help with. I own both routers.
Dec 15, 2021Guru - Experienced User
I've literally had my network setup with both.
But they don't integrate.
What I did was setup the RAX as the primary router. And I connected the Orbi system to it in access point mode.
This allowed me to have peak performance/speeds while connected to the RAX network and for my devices on the peripheral or that moved around a lot, I had on the orbi for better coverage. Just make sure you have the 2 networks on different ssid's and using different wireless channels to prevent interference.
It'd be nice if they integrated together but sadly, they dont.
DearGeo
Dec 15, 2021Tutor
I plugged in my Orbi and I have Frontier FiberOptic 1000 Mbps both up and download. But I noticed with my Orbi, I see speeds up to 990 Mbps (up) and 998 Mbps (down) speed. But with my RAX 200 the most I get is 850 up / 820 down. I have it programs to handle speeds of 1000 Mbps 2.4 ghz and 4800 Mbps 5Ghz. Is there a setting I have to change?
- plemansDec 15, 2021Guru - Experienced User
How are you testing speeds? The built in speedtest isn't that accurate at speeds over 500mbps as it rarely picks the best server.
- DearGeoDec 15, 2021TutorGigabyte tester which I borrowed from Frontier
- plemansDec 16, 2021Guru - Experienced User
DearGeo wrote:
Gigabyte tester which I borrowed from FrontierWhich is what? Just testing the ethernet? Testing the incoming line?
What device is this and how does it accurately test?
Why aren't you testing with your equipment since that'll be whats used at home?
