Hatsukikeika
Dec 19, 2022Initiate
Netgear RAX 43 cannot detect SanDisk Extreme 2TB SSD
I have a AX4200 WiFi Router (RAX43) and I'm trying to have my SanDisk Portable SSD connect to it for ReadySHARE. I tried wait over 2mins, also tried restarting the router. The usb device is sti...
- Dec 19, 2022
exfat would cause issues.
What are the USB drive requirements for ReadySHARE on my NETGEAR router? | Answer | NETGEAR Support
Hatsukikeika
I don't have other usb devices at the moment, this is the first time I use it.
I noticed the SSD is in exFAT format maybe that's the problem?
Dec 19, 2022Guru - Experienced User
