Andy73
Jun 26, 2020Aspirant
netgear rax120 bt iptv setup
i have the bt openreach modem (fttp) .i am trying to set up the netgear Nighthawk® AX12 12-Stream WiFi 6 Router (RAX120) to work with the bt iptv channels like bt sport etc on my bt youview box . it ...
schumaku
Jun 26, 2020Guru - Experienced User
Hard to help if you don't show us what you have configured....
Andy73
i have connected netgear rax120 to the bt openreach fibre modem , done inital setup .then went in to advanced setting on router and unchecked the box Disable IGMP Proxying and checked the box Support British Telecom (BT) IGMP Proxying .
