Rock31482
Jun 09, 2020Guide
Netgear RAX120 Issues
I know that there has been many discussions about the issue I may refer to but this is what I am experiencing. For the longest my router was working fine. Recently, I am having issues with devices n...
Christian_R
Jun 12, 2020NETGEAR Employee Retired
Hello Rock31482,
Welcome to the community! May you send me a private message with your serial number and the current firmware version you have installed on the router.
Thanks,
Christian
- Rock31482Jun 12, 2020Guide
Well yesterday, I had enough I went to the router and decided to reset it from the physical router itself. I then configured it again and it looks like it is working now but I have a feeling that theissues may start again.
- Christian_RJun 15, 2020NETGEAR Employee Retired
Thanks for the update on the thread and glad to hear that everything seems to be working now. I've edited your comment and removed your router's serial number from being displayed publicly.
Christian
- Rock31482Jun 18, 2020GuideIt looks like it is happening again. I have the router exactly the way I want it setup but my wifi is having issues on both bands. I have left the wifi configuration pretty stock but the signal strength is band and the speed on the bands is reduced.
Can you provide help?
