Cretzky
Jun 29, 2020Aspirant
Netgear RAX120 Wifi super slow
Hi, Serious problem with net speed. i Have 1Gb down and 1Gb up as internet speed. Can achieve it once using wire. Router in default settings. Using Iphone 11 Pro 5G and also 2,4G wifi. Basi...
Newfiedrool
Jun 30, 2020Virtuoso
Check for latest firmware and it's up to date then perform a factory reset using the rear pin hole method. Setup as new and do not use a saved profile cfg. Test again.
Cretzky
Jun 30, 2020Aspirant
Newest firmware installed via update and reset via pin hole done. It was the first thing after update.
Pert
Pert
