guccia123
May 31, 2023Aspirant
Netgear RAX120V2 NANC
Hi, Had Beta firmware 1.2.8.43-RC on my RAX120V2. Now I rolled back to 1.2.8.40. Main Reason for roll back was Temperature was showing NANC and auto fan wasn't working. After rolling back (wi...
May 31, 2023Guru - Experienced User
Factory reset and setup from scratch. Should clear our any lingering bad code. I believe NG disabling some of the debug items in the beta FW to help test for this reboot issue that was seen on v.40 FW. I would presume all this would be corrected and fixed in next official FW release.
Something to help with the internal fan, Install a laptop cooler fan under the router for 24/7 cooling.
guccia123
Thanks for fast response.
When is full release expected of v43 firmware ?
And will Restore settings via cfg work or should I manually enter all configs ?
- FURRYe38May 31, 2023Guru - Experienced User
No idea and version may not be v.43
Manually setup from scratch then save off a new backup.
