ax74
Feb 13, 2024Aspirant
Netgear RAX20 L2TP speed problem
Hello there,
I really want to ask for an advise from more experienced users than myself abot L2TP internet speed.
So I bought NetGear AX1800 RAX20 router (latest firmware already installed) a...
Feb 13, 2024Guru - Experienced User
Might have to go with there equipment for better performances. The RAX20 is mostly a entry level router. L2TP is not a commonly used protocol and may not have good performances. Something you do is use there router and configure the RAX20 into AP mode for it's wireless abilities.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
ax74
You suggest using a router as an access point - there are just access points for this, why do I need extra equipment? L2TP routers that have been working for 10-15 years, my old Netgear wndr3700 works fine with l2tp at a speed of 100 megabits. This is not a solution to the problem. I would like to draw the manufacturer's attention to this problem.
