BobE265
May 24, 2020Aspirant
Netgear RAX20 Slow wired connection when Access Control is turned on
Sorry for the RAX200 Model. Gave me no choice for the RAX20.
Just bought the RAX20 modem. Have current firmware, 1.0.1.56
Installed fine. Desktop connected via ethernet. Speedtest show approx. 750Mbps (right in line with ISP)
When I enabled Access Control, it was still showing 750Mbps or so via ethernet.
However, when I began adding allowed MAC addresses, the wired connection dropped to 300Mbps or lower.
I have done a reset, reinstalled firmware, and still have the same problem.
The router I replaced, Netgear AC1600 (R6260), had no problems before or after switching back from the RAX20. Speeds were 750Mbps+ with Access Control enabled.
Thoughts?
- BobE265Aspirant
I also tried enable/disable QOS. No effect
- BobE265Aspirant
Well, I rolled the firmware back to 1.0.1.40 and so far speedtest is showing 750Mbps+ will Access Control on with the wired connection
Im thinking now it has somehting to do with the newer firmware.
- BobE265Aspirant
Rolled up to the next newest firmware, 1.0.1.54 and the speed dropped back down.
