bakerjw
Oct 12, 2022Aspirant
Netgear RAX20 unable to be reset
I have a Netgear RAX20 router that I am trying to configure. I did the reset to factory defaults sequence. Push reset button for 7 seconds. Let it reboot. Power cycle and try to connect to 192.168.1...
Oct 12, 2022Guru - Experienced User
Try pressing the reset button for 10-15 seconds.
If it resets like it should it should come pop a log in screen, there should be a new set up screen with the Nighthawk app on a mobile device appearing on the web browser. Try a different web browser as well. Be sure to clear out ALL browser caches before going to the routers web page.
