bakerjw
Oct 12, 2022Aspirant
Netgear RAX20 unable to be reset
I have a Netgear RAX20 router that I am trying to configure. I did the reset to factory defaults sequence. Push reset button for 7 seconds. Let it reboot. Power cycle and try to connect to 192.168.1...
bakerjw
I went through and did the 30-30-30 reset which made it start behaving in a different manner which is a change.
The system that I am using to configure this has no internet access and is using IP address 192.168.1.200/24. I even went so far as to assign the default gateway and DNS both to 192.168.1.1.
Going to http://192.168.1.1 tries to go to http://routerlogin.net/genie_index.htm.
I need to get control of it so that I can give it a specific IP address and configure it as a wireless access point meeting specific security measures that our corporate infosec group has in place.
Right now, it is kind of accessible but unusable.
Oct 12, 2022Guru - Experienced User
When it redirects you to routerlogin.net, just input 192.168.1.1 again. Also after you factory reset the router, disconnect the router from the ISP modem/ONT. Helps prevent it from loading the external site.
