kuki68ster
Sep 01, 2020Follower
Netgear RAX20 voltage
Hello, I recently bought a netgear RAX20 from the US and it came with a 100/120v charger...Can anyone tell me if the router is compatible with a 220/240v charger? Thanks
michaelkenward
Sep 05, 2020Guru - Experienced User
I have used several Netgear 100/120v adapters in the UK. Not one has gone bang.
But you can use any suitable adapter with the right output.
