someDude11
Jan 31, 2022Follower
Netgear rax200 - QOS checkbox won't check
I don't get it. I can't find this issue anywhere else. I can't enabled QoS on this router. I can't find anyone else with this issue.
Please help. This is a $400 router so it's not like I bought a cheap one.
I'm about read y to look into open source firmware to replace netgears crap.
Specifically, this is the router:
Nighthawk® Tri-Band AX12 12-Stream AX11000 Tri-Band WiFi Router
What is strange is that the checkbox looks enabled (vs a grayed out disabled look) .... it just won't check. I can even run speed test!
1 Reply
A couple things.
1. what mode is it on? router mode? Access point mode?
2. do you have a screen snip?
3. What firmware is on the router?
4. What modem/gateway is it connected to?
5. What speeds do you pay for?
