geowars2
Dec 04, 2023Guide
Netgear RAX200 - Strange fan behaviour and awful fan noise
I am using a Netgear RAX200 router. The router typically has about 50 devices connected, although the majority are IOT devices like lightbulbs which don't have high data or bandwidth demands. Th...
geowars2
Dec 04, 2023Guide
Thanks for the response. It'll take me a while to go through all the steps, particularly the full factory reset.
Great suggestion on temporarily changing the password too. This should help me to rule out the possibility of my devices causing high load.
I'll follow up but too answer some questions so far:
- it's on latest firmware 1.0.6.138
- it's connected to a BT homehub 4 ISP router
- I'm not sure of the network cable standard. I will look at replacing it with the standard you suggest, but I'd have a hard time believing the issue could be related to this.
- smart connect is disabled
- three bands are enabled - channels are Auto for 2.4ghz (currently channel 1+5), 44, 100.
On the prospect of an external fan; I'd hesitate to add an external fan as my router is in my living room and that would affect both the noise and aesthetic.
Also, I suspect that the fan issue is not temperature related for these reasons:
- it seems to come on and off at regular intervals (I'm going to time it when I get a chance to see...)
- Even in low ambient temperature the fan still comes on and off at the same intervals as it did in the Summer time when the ambient temperature was much much higher.
- Having looked at the debug.htm page in my browser, CPU usage is always low
(as an example, this is what it looks like with 45 devices connected: CPU1: 1.48% CPU2: 1.40% CPU3: 0.94% CPU4: 0.94%. I don't think the CPU usage is high enough here to be causing excessive heat...).
I'd also be interested if anyone else with this router can reproduce this issue. All I need to do is open the nighthawk application on my phone, and as soon as it connects, this is what seems to place my router into "noisy mode" where the fan comes on every few minutes and continues to do so indefinitely.
I do think it's whatever way the nighthawk app is connecting to the router, is inducing some bug. I'll do some additional hunting...
Dec 04, 2023Guru - Experienced User
Might update FW as well: https://community.netgear.com/t5/Nighthawk-with-WiFi-6-AX-and/New-RAX80-RAX200-Firmware-Version-1-0-10-140-Released/td-p/2242204/jump-to/first-unread-message
Is this router bridged? Having a router infront of another router can be problematic as well. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
Try option #2 first...
Then fan I suggested has speed controls and is fairly quiet. Would sit under the router.
Ya, Wouldn't be doing that. Lets try a FW update after a factory reset to check this.
Your the first reporting this kind of fan behavior.
- geowars2Dec 04, 2023GuideThanks again.
Apologies, I am already on the latest firmware (V1.0.10.140_1.0.79), not sure where I got the other version from.
The BT homehub router does not support a bridge or modem only mode. Given the docs you linked, I'll look into setting the Netgear to access point mode but I will read the docs first, as I don't understand its side effects well and don't want to negatively affect my IoT devices which generally work fine.
Fwiw, The routers are approximately 40-50cm apart and whilst I can disable the wireless radios on the homehub, I've actually chosen to enable the 2.4ghz radios on the opposite end of the spectrum in my ISP router, so that I can connect some devices it (currently there are 16). Unfortunately I have at least one device which refuses to work with the Netgear router, notably my Nest smoke alarm, so this forced me to do so. I then connected some additional devices to my ISP router for the purpose of spreading the load.
I'll look into the fan some more, so thanks for that. If I could look into using a noctua fan through a controller that would be ideal as I'm not, excuse the pun, the biggest fan of fan noise.- FURRYe38Dec 04, 2023Guru - Experienced User
Lets try a Factory reset and if you can try option #2 on the ISP router for the RAX. Lets try the ISP routers DMZ for the RAX in router mode as well.
But first thing, try changing the pass word on the SSID and see what happens.
Ya the fan in this routers are the greatest. Why I chose a external fan solution for my needs.
Keep us posted on how it goes.
- geowars2Dec 04, 2023GuideI appreciate it.
An easy option for me to try right now is setting up my Netgear in access mode so I have completed that and things are working ok. I will see how it goes with this, before I jump to the factory reset and consider the other options like the DMZ stuff that I'm not too familiar with (sorry, not a networking expert!)
Since I had rebooted earlier the fan issue isn't actually presenting right now and there are over 40 (mostly iot) WiFi devices connected to the router. I will also wait to see if the fan starts spinning up before I change the WiFi password.
- michaelkenwardDec 04, 2023Guru - Experienced User
geowars2 wrote:
The BT homehub router does not support a bridge or modem only mode.Yes. BT's hardware is best avoided. I have several still in their shrink-wrap.
Unless you are on BT's IP telephony service, other options are available. Even with that, you may find workarounds.
The Homehub 4 is a DSL modem/router. Is that the service you are on?
Unfortunately, Netgear, and most brands, abandoned the DSL modem market some time ago.
I got in just before that happened and switched to a pair of Netgear DM200s. (One of those was an open box resell.) I have used these alongside a raft of different Netgear routers.
If you are prepared to buy reused, the spread of BT's fibre-optic-to-the-home service has created a good market for second hand DM200s. Strongly recommended. That would be a great feed for the RAX200 .
Not sure if it would do much about the fans. Have you looked at:
http://routerlogin.com/debug.htm
That can have some hidden settings.
I'll look into the fan some more, so thanks for that. If I could look into using a noctua fan through a controller that would be ideal as I'm not, excuse the pun, the biggest fan of fan noise.I suspect that this is a red herring. The UK is not exactly tropical, especially now.
How old is your router? Less than a year and I'd be tempted to go for a warranty RMA.
- geowars2Dec 04, 2023GuideThanks for the reply.
I'm mistaken, it's actually a BT Smarthub 2 I have.
To clarify, It's a fibre connection into my home, which connects to an Openreach Modem (ONT). That modem connects to the Homehub 5 via ethernet, and then my Netgear router is connected to the Homehub via ethernet.
I'm on the BT fibre to the home 900mb service and fwiw I actually can achieve the 900mb speed through my Galaxy S23 connected to the Netgear RAX200.
I don't use the BT telephony service at all, and never will.
The homehub, despite being a basic modem/router, is still surprisingly reliable, And although I'll never get the speeds I can get through the Netgear, I've actually had better luck connecting some devices to it versus my Netgear.
I'd be open to using something like the DM200 but given the fact that a separate modem is used in addition to the smarthub, it may actually be possible for me to eliminate the Smarthub router completely anyway. I've just looked and this is actually possible.
This would be good as it would make things simpler and power consumption would be reduced.
The things that gives me pause in doing this are :
- If I remove the smarthub I will have all devices connected to Netgear which will be around 60 active connections (albeit most iot devices)
- The fact that one or two devices I have simply will not play ball with my Netgear router.
The notable example is my Nest smoke alarm, which can connect to the router on an initial setup but then after the smoke alarm disconnects from WiFi (it does this by design because it's battery powered), it never connects ever again. I've had no issues when connecting it to the homehub! I could maybe try again with my Netgear in AP mode just to see if that could have resolved it, since I do understand that the "Double NAT" issue can cause compatibility issues.
On temperature: I'm in Ireland in a 1935 constructed house, so ambient temperature in the room with my router relatively low!
Lastly, my router is probably now out of warranty, having purchased it in August 2022.
