geowars2
Dec 04, 2023Guide
Netgear RAX200 - Strange fan behaviour and awful fan noise
I am using a Netgear RAX200 router. The router typically has about 50 devices connected, although the majority are IOT devices like lightbulbs which don't have high data or bandwidth demands. Th...
geowars2
Dec 04, 2023Guide
Thanks again.
Apologies, I am already on the latest firmware (V1.0.10.140_1.0.79), not sure where I got the other version from.
The BT homehub router does not support a bridge or modem only mode. Given the docs you linked, I'll look into setting the Netgear to access point mode but I will read the docs first, as I don't understand its side effects well and don't want to negatively affect my IoT devices which generally work fine.
Fwiw, The routers are approximately 40-50cm apart and whilst I can disable the wireless radios on the homehub, I've actually chosen to enable the 2.4ghz radios on the opposite end of the spectrum in my ISP router, so that I can connect some devices it (currently there are 16). Unfortunately I have at least one device which refuses to work with the Netgear router, notably my Nest smoke alarm, so this forced me to do so. I then connected some additional devices to my ISP router for the purpose of spreading the load.
I'll look into the fan some more, so thanks for that. If I could look into using a noctua fan through a controller that would be ideal as I'm not, excuse the pun, the biggest fan of fan noise.
Dec 04, 2023Guru
Lets try a Factory reset and if you can try option #2 on the ISP router for the RAX. Lets try the ISP routers DMZ for the RAX in router mode as well.
But first thing, try changing the pass word on the SSID and see what happens.
Ya the fan in this routers are the greatest. Why I chose a external fan solution for my needs.
Keep us posted on how it goes.
- geowars2Dec 04, 2023GuideI appreciate it.
An easy option for me to try right now is setting up my Netgear in access mode so I have completed that and things are working ok. I will see how it goes with this, before I jump to the factory reset and consider the other options like the DMZ stuff that I'm not too familiar with (sorry, not a networking expert!)
Since I had rebooted earlier the fan issue isn't actually presenting right now and there are over 40 (mostly iot) WiFi devices connected to the router. I will also wait to see if the fan starts spinning up before I change the WiFi password.
