geowars2
Dec 04, 2023Guide
Netgear RAX200 - Strange fan behaviour and awful fan noise
I am using a Netgear RAX200 router. The router typically has about 50 devices connected, although the majority are IOT devices like lightbulbs which don't have high data or bandwidth demands. Th...
Dec 04, 2023Guru - Experienced User
Lets try a Factory reset and if you can try option #2 on the ISP router for the RAX. Lets try the ISP routers DMZ for the RAX in router mode as well.
But first thing, try changing the pass word on the SSID and see what happens.
Ya the fan in this routers are the greatest. Why I chose a external fan solution for my needs.
Keep us posted on how it goes.
geowars2
Dec 04, 2023Guide
I appreciate it.
An easy option for me to try right now is setting up my Netgear in access mode so I have completed that and things are working ok. I will see how it goes with this, before I jump to the factory reset and consider the other options like the DMZ stuff that I'm not too familiar with (sorry, not a networking expert!)
Since I had rebooted earlier the fan issue isn't actually presenting right now and there are over 40 (mostly iot) WiFi devices connected to the router. I will also wait to see if the fan starts spinning up before I change the WiFi password.
