DoubleACIty's avatar
DoubleACIty
Follower
Sep 26, 2021
Netgear RAX200 firmware 1.0.5.132 disables wifi channel NETGEAR51-5G-1
A few days ago, i noticed my fastest Wi-Fi channel had disappeared, the NETGEAR51-5G-1 of my RAX200, and I didn't understand why? So i decided to see what may be the possibility and I noticed that a firmware update came out at the same time it went down. So I reverted to the previous Firmware and the Wi-FI channel returned and I was able to connect to it like normal again.
Please have this issue patched by the next Firmware please.
Thank you.
1 Reply
  • plemans's avatar
    One thing to try is after you update is to try to factory reset.
    Sometimes old settings cause issues and a reset can fix it
