NandoFL
Dec 16, 2019Star
Netgear RAX200 get very warm to the touch. Is this is normal?
I have a brand new Wifi 6 RAX200 router. Like the subject said, it does get very warm to the touch always. The enviroment in my room is about 70F. Always cool and it have complete ventilation. It is ...
Dec 17, 2019Guru - Experienced User
Mine gets warm but not hot.
has your fan ever kicked on? If not, I wouldn't worry. I've only gotten mine to kick on a single time and I was stress testing the router quite significantly. the rest of the time its just warm to the touch.
Make sure nothing is blocking the ventilation.
NandoFL
Dec 17, 2019Star
The fan did turn on for a short period of time only a couple of time and not for long. For the most part the fan is not running. Maybe the router was stressed for a short while. So far is just warm and fan is not coming back on.
