DJScotty9000
Jul 09, 2021Tutor
Netgear RAX200
I am just wondering is it normal for the Netgear nighthawk RAX200 AX11000 to disconnect from Power with cable at end that plugs in to the back router. I understand it has no central pin.
Jul 09, 2021Guru - Experienced User
I'm not sure what your actually asking here.
Some clarity as well as what your trying to do might help
- DJScotty9000Jul 09, 2021Tutor
What I mean if I plugged it in sometimes the router disconnects when I move it. Just to on the safe side I bought a replacement online. I am just making absolutely sure that is not meant to do that. I can't see no central pin inside the little plug do I have to be concerned about that I am new to Netgear Routers.
plemans wrote:I'm not sure what your actually asking here.
- plemansJul 09, 2021Guru - Experienced UserHave you tried to read/understand what you just wrote?
