khaled9999
Dec 12, 2021Follower
Netgear RAX200
If I connect a Dual Band access point device to this Tri-Band router, will the speed of the connectors through the access point slow down, and will they not benefit from the router’s features such ...
Dec 12, 2021Guru - Experienced User
what one are you thinking of connecting?
It isn't going to slow the RAX200 down any.
Usually the bottleneck is for the devices connected to the extender since the RAX200 is pretty miuch the top of the line router
