ngaybuon555
Feb 21, 2022Aspirant
Netgear RAX35 setting by browser keep revert
Hi I tried to change the wireless SSID and paword on Netgear RAX35 but keep revert to default SSID and password (the one on the back of router) even I updated router the the newest firmware. Tried a...
microchip8
Feb 21, 2022Master
This sounds like a bug. Have you opened a support ticket? If not or your 90 days free suppport has expired, revert to a previous firmware version and do a factory reset and configure from scratch
ngaybuon555
.microchip8. Thanks for the replied. I already factory reset that is why the SSID and password keep revert to default. I will try revert the firmware later when I am home (at work now) but that happen on the old and then newest firmware.Do you think the web browser have anything to do with the issues? Thanks in advance.
- microchip8Feb 21, 2022Master
It depends, but in your case I highly doubt that. If you tried many different browsers and it still happens, then there's a bug in the firmware and/or Web UI. If it's really a bug, then I can't help much. Best is to contact NETGEAR and see what they say (unless your 90 days free support has expired)
- ngaybuon555Feb 21, 2022Aspirant
microchip8.
I did downgraded the router firmware to the oldest version V1.0.3.62 available in Netgear website and able to changed the setting using WebUI. Thank you!
