shibic
Dec 08, 2022Follower
Netgear RAX50 block incoming ip address
Hello, I wanted to allow only few incoming IP address which is going to hit my local server. other that that all other IP Address should not connect.
michaelkenward
Dec 09, 2022Guru - Experienced User
That's a pretty general request that could mean many things and might benefit from a bit more background.
Why do you want to do that and what is the final objective?
Have you looked at what the router does without you having to change anything?
Have you been through, and tried, the various settings described in the manual?
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
