raichu059's avatar
raichu059
Follower
Jul 22, 2023
NETGEAR RAX50 vs RAX50v2
Does anyone know the exact technical differences between NETGEAR RAX50 and RAX50v2?
The firmware version differs which raises a few flags.
Different switch chipset? Different Wi-Fi chipset? Etc.
Is v2 better than the original?
Not sure if I should hunt for an original RAX50.
Local Best Buy had v2 on the shelf.
https://www.reddit.com/r/NETGEAR/comments/156llry/netgear_rax50_vs_rax50v2
1 Reply
  • If it has a different firmware then most likely has a different/upgraded chipset that isn't compatible with the v1 firmware SDK.
    For exact technical details, you'd have to contact NETGEAR.
