jklow's avatar
jklow
Follower
Nov 07, 2021
Netgear RAX50 Web UI Timeout
Hello,
I currently have a RAX50 using firmware 1.0.4.100 and my Web UI would time out after a few minutes.  I would browse my settings in advanced tab and the spinning circle would stay there and eventually time out.  I tried accessing through my nighthawk mobile app and it would no longer connect.
Things I've done:
Soft reset.  UI would work for a few moments then timeout again
Hard Reset.  Held the reset for 30 seconds and setup my network again.  UI would timeout after a minute or so.
I did enable HTTPS under Web Management prior to all this starting.  Ever since updating to firmware 1.0.4.100 my connections have dropped way more often than before and now I can't access my UI unless I perform a reset and even then it would eventually timeout while I'm in the UI.
Note:  My internet is still working normally while I cannot connect to the router.  LAN & Wifi
1 Reply
  • FURRYe38's avatar
    What browser are you using? Try MS Edge, Firefox or Opera?
