Compgeke
Mar 22, 2023Follower
Netgear RAX54 Static Routes Don't Allow WAN Access
I've got a fun issue and I can't seem to actually contact support over it, despite being more of a bug.
On the RAX54 (AX5400) I can create a static route, however said route does not get WAN access.
You can ping and access anything within the LAN, however there is no WAN access going through the route. Tracert shows it dying at the router, with no ability to ping public IPs or anything.
Is it a possible to submit a bug report at all?
1 Reply
Have you tried setting a reserved ip address instead of a static route?
