skynettriangle
Sep 18, 2020Aspirant
netgear rax75 won't work from a switch
I bought one of the new Netgear AX8 routers (rax75) yesterday as I had the netgear nighthawk ac1900 and with the number of devices I have on it, the router started to die. I have a switch in my house...
Christian_R
Sep 25, 2020NETGEAR Employee Retired
Hello skynettriangle,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
http://www.netgear.com/support/contact.aspx
Christian
