thegadgetguy
Dec 02, 2021Aspirant
Netgear RAX80 and Amysen / any other similar smart socket / plug and Smart Life App
Having an issue with new smart plugs trying to add to app / network. So I bought the same brand a year ago (at the time I had an older Netgear 2.4/5GHZ Router) and they connected no issue with S...
thegadgetguy
So Smart Connect is not on, but will try changing the Wifi SSID. Right now they are just separated by 2.4 or 5 but the name is the same, meaning network 2.4 and network 5g (for example). Are you suggesting i change the name completely to something else to test this?
Should I throttle it down to 54mbps as right now under 2.4 its set at "up to 1200 mbps"?
thegadgetguy
Dec 03, 2021Aspirant
Ok so tried changing SSID for 5 ghz to something comepletely different and still nothing.
Have switched from Channel 1 to another Channel and still nothing.
- FURRYe38Dec 03, 2021Guru - Experienced User
As a quick test, disable WPA security on the wifi router, connect the setup mobile device to the wifi while in the open. Can you connect these devices to the router then?
Re-enable WPA2 and AES after checking this...- thegadgetguyDec 03, 2021Aspirant
I was so hoping this would solve it, the easiest hurdle to climb. Still not working however. But with that said i had restored the rest of my settings back to normal aside from the removal of WEP on 2.4ghz. This is crazy because I had an older 5GHZ Netgear router which worked fine with the same kind of plugs about a year ago. The only thing that changed was I upgrade to the RAX 80 to take advantage of the new fiber internet I have coming into my house.
So disabling WPA on the RAX doesn't work?
WEP is old wifi security and is not longer supported on most current generation routers. WEP was compromized years ago and removed from service from most current generation routers. If you have WEP devcies, these will not connect to current gen routers. You may need to find an older router that supports WEP or upgrade these WEP devcies to something that supports WPA2 and AES at least.
Seems like there maybe some compatibility issues with these particular devices and RAX. You might contact the mfr of these devices for additional help and information regarding there product.
