userlee1983
May 03, 2023Aspirant
Netgear rax80 option 61
Hello I have sky which requires option 61. I have set this up before with asus routers but with this Netgear I just can't find the option 61 to use my username and password. It's updated to the ...
- May 03, 2023Sorry yes latest firmware and it was in advanced-setup internet- choose internet doesn't require login use dhcp then at the bottom of the same page there was option 61 used the anything@skydsl|anything as user string and it worked after rebooting sky's ont for twenty minutes
microchip8
May 03, 2023Master
I don't think it it supported yet. Your best bet is to contact NETGEAR and do a request.
