userlee1983
May 03, 2023Aspirant
Netgear rax80 option 61
Hello I have sky which requires option 61. I have set this up before with asus routers but with this Netgear I just can't find the option 61 to use my username and password. It's updated to the ...
- May 03, 2023Sorry yes latest firmware and it was in advanced-setup internet- choose internet doesn't require login use dhcp then at the bottom of the same page there was option 61 used the anything@skydsl|anything as user string and it worked after rebooting sky's ont for twenty minutes
May 03, 2023Guru - Experienced User
What firmware version are you on?
It looks like its supported on versions 1.0.3.88 and above.
https://kb.netgear.com/000062426/Which-NETGEAR-routers-support-DHCP-option-60-and-61
- userlee1983May 03, 2023AspirantV1.0.10.140. the option is no were to be seen. I bought this following the link above saying this router supports option 60 and 61
- FURRYe38May 03, 2023Guru - Experienced User
Wondering if you downgraded the FW to v1.0.3.88 to see if it's there would help you. Possible it's broke in current versions of FW.
- userlee1983May 03, 2023AspirantHave you any ideas were I would find option 61 maybe I'm doing something wrong and I can't access it
