userlee1983
May 03, 2023Aspirant
Netgear rax80 option 61
Hello I have sky which requires option 61. I have set this up before with asus routers but with this Netgear I just can't find the option 61 to use my username and password. It's updated to the ...
- May 03, 2023Sorry yes latest firmware and it was in advanced-setup internet- choose internet doesn't require login use dhcp then at the bottom of the same page there was option 61 used the anything@skydsl|anything as user string and it worked after rebooting sky's ont for twenty minutes
May 03, 2023Guru - Experienced User
What firmware version are you on?
It looks like its supported on versions 1.0.3.88 and above.
https://kb.netgear.com/000062426/Which-NETGEAR-routers-support-DHCP-option-60-and-61
userlee1983
V1.0.10.140. the option is no were to be seen. I bought this following the link above saying this router supports option 60 and 61
- FURRYe38May 03, 2023Guru - Experienced User
Wondering if you downgraded the FW to v1.0.3.88 to see if it's there would help you. Possible it's broke in current versions of FW.
- userlee1983May 03, 2023AspirantHave you any ideas were I would find option 61 maybe I'm doing something wrong and I can't access it
Maybe different location but on the R9000 seen here, its located under Advanced tab/Internet menu option at the bottom:
https://www.reddit.com/r/NETGEAR/comments/1368ap8/issue_with_netgear_nighthawk_wifi/
Only other place to try a look for this maybe under Advanced tab/Advanced settings maybe.
If not seen anywhere on current version of FW, might roll back to was was suggested and see.
Might have to contact NG support for help on this.
