userlee1983
May 03, 2023Aspirant
Netgear rax80 option 61
Hello I have sky which requires option 61. I have set this up before with asus routers but with this Netgear I just can't find the option 61 to use my username and password. It's updated to the ...
- May 03, 2023Sorry yes latest firmware and it was in advanced-setup internet- choose internet doesn't require login use dhcp then at the bottom of the same page there was option 61 used the anything@skydsl|anything as user string and it worked after rebooting sky's ont for twenty minutes
michaelkenward
May 03, 2023Guru - Experienced User
For future reference:
Search - NETGEAR Communities – option 61
It's a regular.
- userlee1983May 03, 2023AspirantDoes this router actually output wifi6 or does it use the 5g channel for wifi6. As nothing shows as WiFi 6. Got my ps5 that doesn't show. I have ax enabled
- FURRYe38May 03, 2023Guru - Experienced User
WiFi6 = AX mode on 5Ghz
WiFi6E = AX mode on 6Ghz
Does the PS support AX modes on 5Ghz? Something to ask Sony about.
- userlee1983May 04, 2023AspirantThe only thing I can see that's not working is ipv6. As anyone got any ideas. I've got it set to dhcp but it won't get the ipv6 address
