userlee1983
May 03, 2023Aspirant
Netgear rax80 option 61
Hello I have sky which requires option 61. I have set this up before with asus routers but with this Netgear I just can't find the option 61 to use my username and password. It's updated to the ...
- May 03, 2023Sorry yes latest firmware and it was in advanced-setup internet- choose internet doesn't require login use dhcp then at the bottom of the same page there was option 61 used the anything@skydsl|anything as user string and it worked after rebooting sky's ont for twenty minutes
userlee1983
Does this router actually output wifi6 or does it use the 5g channel for wifi6. As nothing shows as WiFi 6. Got my ps5 that doesn't show. I have ax enabled
May 03, 2023Guru - Experienced User
WiFi6 = AX mode on 5Ghz
WiFi6E = AX mode on 6Ghz
Does the PS support AX modes on 5Ghz? Something to ask Sony about.
- userlee1983May 04, 2023AspirantThe only thing I can see that's not working is ipv6. As anyone got any ideas. I've got it set to dhcp but it won't get the ipv6 address
- FURRYe38May 04, 2023Guru - Experienced User
Contact the ISP for IPv6 configuration requirements. They should know. You may have to use one of the other configurations.
- KitsapMay 04, 2023Master
userlee1983 wrote:
The only thing I can see that's not working is ipv6. As anyone got any ideas. I've got it set to dhcp but it won't get the ipv6 addressIn the Advanced -> Advanced Setup -> IPv6 tab, have you enabled IPv6?
- userlee1983May 04, 2023AspirantYes it's enabled
- michaelkenwardMay 04, 2023Guru - Experienced User
userlee1983 wrote:
The only thing I can see that's not working is ipv6. As anyone got any ideas. I've got it set to dhcp but it won't get the ipv6 addressWhen this happened to me on a different router. I took the IPv6 setting through "Auto detect".
- Advanced
- Advanced Setup
- IPv6
That found the ISP's implementation.
- userlee1983May 04, 2023AspirantTried the auto config. It's setup a new way it shows one ipv6 address but still isn't showing ipv6 address says not found when using what's my IP address
