userlee1983
May 03, 2023Aspirant
Netgear rax80 option 61
Hello I have sky which requires option 61. I have set this up before with asus routers but with this Netgear I just can't find the option 61 to use my username and password. It's updated to the ...
- May 03, 2023Sorry yes latest firmware and it was in advanced-setup internet- choose internet doesn't require login use dhcp then at the bottom of the same page there was option 61 used the anything@skydsl|anything as user string and it worked after rebooting sky's ont for twenty minutes
Kitsap
May 05, 2023Master
userlee1983 wrote:
Been through all the ipv6 settings and auto detect changes it to 6x4 channel and it sets a IPV6 address to the router but fails to work still odd
I've noticed aswell as I read somewhere if I delete the option 61 identifier and put it as a option 60 identifier the ipv6 will work.
But it doesn't but the internet still works
So now I ask what's the difference between option 60 and option 61 should one be used over the other or should both be filled in?
Sorry to go on lol
If you have not done so, recommend you go check out the discussions here: https://helpforum.sky.com/
There are a significant number of posts about users replacing the sky hub with a third party router.
userlee1983
May 05, 2023Aspirant
I have it working. Just no ipv6
And I was wondering what the difference is between option 61 and option 60
