rick0518
Sep 23, 2023Aspirant
netgear raxe500 6e with iphone 15 pro max?
Hi I Have a Netgear Raxe500 (North America), and now I live in Taiwan yesterday I tried to connect wifi 6e, first time is successfully connected. but after a few hours, my iPhone 15 pro max can...
michaelkenward
Sep 23, 2023Guru - Experienced User
rick0518 wrote:
but after a few hours, my iPhone 15 pro max can't find my 6e SSID anymore, only 2.4g 5g,
What tells you that this is due to the router rather than the iPhone?
Can other devices see the SSID.
Do you have separate SSIDs for 6 GHz? (My router mashes them all together.)
Did you see this?
NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
rick0518
michaelkenward Thank you for your reply
I have only two iPhone 15 pro max (one ios 17.0.0, second is 17.0.2)
I read this, but my issue is in my iPhone Settings > Wi-Fi, can't find my 6G SSID
for iPhone use the wifi 6g channel do I need to do a special setting?
may I ask is the American version of Raxe500 with taiwan cellphone problems? like region code or something like that.
- michaelkenwardSep 23, 2023Guru - Experienced User
Maybe on the iPhone. The router doesn't care what wifi clients look for it.
You'll have to ask Apple for guidance on their hardware.
may I ask is the American version of Raxe500 with taiwan cellphone problems? like region code or something like that.Possible.I'm not familiar with the different international standards for 6 GHz wifi.
Sadly, devices sold in North America are region locked. This is not the case with devices sold in other markets. where you can change the region.
