rick0518
Sep 23, 2023Aspirant
netgear raxe500 6e with iphone 15 pro max?
Hi I Have a Netgear Raxe500 (North America), and now I live in Taiwan yesterday I tried to connect wifi 6e, first time is successfully connected. but after a few hours, my iPhone 15 pro max can...
Razor512
Sep 23, 2023Prodigy
Keep in mind that due to 6GHz band not being widely used in many countries, and even restricted in a number of them, many regulatory bodies, including the FCC require APs and clients to listen for beacons of nearby APs and devices to determine the regulatory region, and then disable frequencies that are not allowed.
https://en.wikipedia.org/wiki/List_of_WLAN_channels#6_GHz_(802.11ax_and_802.11be)
Beyond that, it is hard to find a list of the regulations in Taiwan but unless they allow it, there is a chance that the AP or even the phone WiFi adapter has changed its regulatory region automatically due to arbitrary draconian regulations. For example in the image below that will be a common response from device makers to be legally allowed to sell their stuff in the US.
- rick0518Sep 23, 2023Aspirant
Razor512 Thank you for your reply
I just don't understand, why only one time can connect wifi 6 after ssid can't find it
I try to reset iPhone / netgear but still can't
- Razor512Sep 23, 2023Prodigy
What needs to be determined are the regulations in Taiwan for the 6GHz band. For example, if the AP tries to use a channel that is not allowed in a different country, then devices there, will not see the SSID until the AP switches to a supported channel.
Beyond that, if in a region where none of the channels are allowed, then once the device detects beacons indicating a different region, the device may stop transmitting on the disallowed frequencies to comply with local laws. For me, it is hard to determine exactly how Netgear implemented their compliance functions as device makers aren't limited on how they go about complying, as long as they ensure that a device when leaving the jurisdiction of one country, and then entering another, has some way of avoiding any major violations of the broadcast laws of that country.
The challenge is that the iphone will have its own implementations of compliance.The WiFi alliance has not updated their page to provide details on Taiwan https://www.wi-fi.org/countries-enabling-wi-fi-in-6-ghz-wi-fi-6e
Beyond that, other sites have mixed messaged surrounding if 6GHz has been officially allowed, and in every case, no one is mentioning which frequencies within the band are allowed.
For example, if they have officially allowed it, but only a small segment of the 6GHz band, then you would have to ensure that the RAXE500 was set to use a channel in the allowed frequency before the RF transmitter will actually enable itself. (if it used one of those automated beacon approaches to regional compliance.
