duckware
Dec 29, 2023Prodigy
Netgear router in AP mode sending out SSDP packets with a public IP address
Netgear, you have a bad SSDP bug. When my RAX50 and RAX54 are in AP mode -- and on my LAN with a 192.168.1.XXX IP address -- the AP's are sending out SSDP packets with a incorrect source IP address ...
duckware
Dec 29, 2023Prodigy
Netgear AP is responding to 75.2.84.193
duckware
Dec 29, 2023Prodigy
Yep, AP thinks it is 75.2.84.193
- FURRYe38Dec 29, 2023Guru - Experienced User
Is this a V1 RAX50?
If so, can you load up more resent FW and give your findings and results?
- duckwareDec 29, 2023Prodigy
.128 FW still has an issue: RAX50 running V1.0.15.128_2.0.89 thinks it is 75.2.84.193
have not checked SSDP and other items, but fact Router responds to "75.2.84.193" (tracert) is very problematic. Wireshark trace shows this coming from MAC address of AP.
And a factory reset and setup from scratch as performed after the FW update then configured for AP mode?
What is the brand and model host router that the RAX are connected too while in AP mode?
And brand and model if ISP modem or ONT that your using?
And curious if you have any Amazon devices on your network by chance.
