Allen_non
Aug 05, 2025Aspirant
Netgear router models are RAX45-100NAS and RAX54-100NAS
Hi, Allen_non here. I'm a competent computer user, also able to set up MAC filtering, and similar level operations on routers, but am lost in the weeds when it comes to ports, channels, etc inside t...
Allen_non
Hi NetGear Community,
Allen_non here. I am a competent computer user, mechanical engineer, etc, so I can interact with my routers, but I don’t understand the “deep magic”, ie port forwarding, bridges, channels, etc. As such, I leave settings as factory default if I don’t know what they do. I do have all my routers set for MAC filtering to block any devices whose MAC addresses are not recorded in the Approved Device List.
I believe I’m encountering a very similar issue as “So_tired”.
Issue:
After running fine for several years, about 6 weeks ago, my 2 Netgear routers lose internet connection regularly and precisely every Tuesday around 12:25 PM EDT (daylight saving time). At that time, our NG routers lose internet and have to be rebooted to fix. I have not waited for extended times to see if they recover on their own, as several family members work from home and need the connection restored pronto.
When I checked the router logs, they show several hundred entries starting around 12:25 PM. A few sample lines read:
[DoS attack: Fraggle Attack] from source 192.168.1.254,port 67 Tuesday, Aug 05, 2025 11:29:53
[DoS attack: NetBiosReplyDrop] from source 10.0.0.3,port 137 Tuesday, Aug 05, 2025 11:29:47
whereas the vast majority of lines read :
[DoS attack: TCP SYN Flood] from source 192.168.1.254,port 38200 Tuesday, Aug 05, 2025 16:23:37
Set up:
ISP is ATT fiber going to ATT provided router (Arris BGW210). Arris “feeds” via ethernet my two NetGear routers, RAX45-100NAS and RAX54-100NAS. All 3 routers update their firmware automatically, and I recently verified they are all up to date.
I have very little running on the Arris. It supplies connection to the Netgears. I can access it via wifi or ethernet for checking settings, etc, but I generally just use it as “gateway”.
Netgear RAX-45 is used for home office, connecting 2 desktops via ethernet, and a couple of laptops via wifi. Other than that, I keep extraneous devices off this router.
RAX-54 is in our living room and networks all our various devices such as smart switches, thermostats, wifi cameras, phones, etc.
Note: I have one old Netgear R7000 router that is connected to RAX-45, that connects to our Ooma VOIP box and a 3D printer that is only on when I’m printing. Even while the RAX-45 seems to lose connectivity, the R7000 seems to maintain its connection.
I have no idea how to fix this, and appreciate any help you all have. I’d rather not have to buy 2 new routers. Nothing has materially changed in the last 6 weeks that I can think of. All routers have been rebooted several times. I can get you .cfg files and or log files if that will help. Thanks in advance!
~Allen
