Devout_Fenrir
Dec 12, 2023Follower
Netgear Router RAX70 has started blocking whatsapp and PS5s access to internet
Yesterday evening router has prevented access to the internet for both the playstation and whatsapp exclusively. Worked fine up until then no obvious change.
Dec 12, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Do you have Armor or Smart Parental Controls enabled on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
