patrickbedgood
Nov 06, 2020Apprentice
NetGear Support Call Issue
I contacted NetGear Support today because I had a hardware problem with my router. This afternoon, my WiFi module was completely disabled and when trying to enable, there were no options to enable Wi...
michaelkenward
Nov 07, 2020Guru - Experienced User
patrickbedgood wrote:
I contacted NetGear Support today ....
How? A number you found with a web search? If so, that wasn't Netgear.
For warranty, start the RMA process by checking MyNetgear.
How do I request a Return Material Authorization (RMA)? | Answer | NETGEAR Support
schumaku
The KB entry looks incomplete to me.
The process does start here in most markets:
Head to https://my.netgear.com -> [My Support] -> Replace my defective product
Netgear does provide a case number and a phone number you have to call where they will do some Q&A to confirm the device need a replacement. Takes typically a minute or two to get the RMA process rolling.
There is no need to subscribe any additional contract or support service to claim your hardware warranty.
- michaelkenwardNov 07, 2020Guru - Experienced User
That does not surprise me in the least.
If that is the case, then I'll see if we can poke someone at Netgear into action.
- schumakuNov 07, 2020Guru - Experienced User
