Sagoo's avatar
Sagoo
Follower
May 20, 2020
NETGEAR WI FI 6
I want to know which is the best Netgear Wi Fi 6 router for FTTP NBN in Australia and with Tri Band. If you can give me the model numbers please?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    There really is no such thing as "the best". And as long as you get the front end right, which depends on your Internet service provider, any router should work.
    A good place to start is with the product pages. Fill in your needs and circumstances, and see what comes up.
    Routers here:
    Wifi Router | Wireless Routers for Home | NETGEAR
    Fancier stuff with a focus on wifi here:
    Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
    See what takes your fancy, and what fits in with your budget. Then check this place for users views. (But remember this place is where people bring problems, not praise.) And see if you can find a review site that covers what you are thinking of buying.
