lsloss
Apr 27, 2025Follower
netgear42-5G need 2.4 GHz for my HP printer
Can I get 2.4 GHZ on my router?
All routers have 2.4Ghz.
What model NG router do you have?
Get with HP support for help and information regarding there printers.
The usual way to fix wifi printers is to find the printer maker's utility, the software that runs on your operating system. Then use that to connect the printer to the wifi.
The router just broadcasts wifi. It is then down to the printer to play ball. There isn't much that you can do on a router, beyond fixing it to a particular IP address, that affects what the printer gets up to.
Fix Wireless Printer Issues | HP® Support
Where possible, using the WPS feature can simplify things.
Disclaimer: Just another user with time on their hands.
