JohnDiV
Jul 09, 2020Star
Netgear's Respone to Issues Relating to IPV6 is extremley poor
Netgear has not solved the IPV6 issue that arose on the 1.0.2.88 and 1.0.2.92 firmeware update. I have talked to them. They know about it ,or so they say, and have not to date came up with a fix. I ...
Jul 10, 2020Guru - Experienced User
the fix is in testing from my understanding.
But it has to be tested prior to rollout to make sure it doesn't make things worse.
