fro10987
Apr 29, 2020Aspirant
network configurating
i am looking for help with my network configuration. i am a NOVICE and only seem to know enough to get me in trouble. i am trying to connect all of my devices that are in 2 seperate buildings on t...
michaelkenward
Apr 30, 2020Guru - Experienced User
fro10987 wrote:
...along with another netgear wireless router (dont have model number at the moment).
Find the model number, read the manual, work out how to put it into wireless access point (AP) mode.
You don't want two routers in a "daisy chain" like that.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
- fro10987Apr 30, 2020Aspirant
am i correct to assume that you mean to change teh router in building b to acess point
- michaelkenwardMay 01, 2020Guru - Experienced User
Yes. I would have put in the model number, but you did not know it.
