robbiekw
Jul 13, 2021Follower
network connect
I connected the router and Netgear shows up as one of my networks. When I start my laptop, it selects NetGear as my preferred network... But when I select Netgear ... and connect to it ... It conn...
Jul 14, 2021Guru - Experienced User
When you say "choose my providers network" does your isp's network have wifi?
that causes a double nat and can create issues.
What is Double NAT? | Answer | NETGEAR Support
Try putting the netgear into access point mode.
Or your networks device into modem only mode.
what modem/gateway is it?
