thomasyim02
Mar 15, 2020Aspirant
Network crashes after upgrading my Galaxy Note 10+ to Android 10
Recently, I upgraded my Samsung Galaxy Note 10+ to Android 10. I discovered that the network connection between my smartphone and RAX80 is unstable. Then I searched related issue on Google and found ...
Christian_R
Mar 17, 2020NETGEAR Employee Retired
Hello thomasyim02,
Welcome to the community! May you let me know if you have QoS or smart connect enabled. If so, may you try disabling to see if there are any improvements.
Thanks,
Christian
- thomasyim02Mar 23, 2020Aspirant
Hi Christian,
I have tried QoS and Smart Connect. Either turned it on or off does not have any improvement regarding to this compatibility issue.
BR,
Thomas
- Christian_RMar 24, 2020NETGEAR Employee Retired
Hi Thomas,
We recently released a new firmware version. May you check to see if there is a firmware update using the Nighthawk app or web interface.
Thanks,
Christian
- thomasyim02Mar 30, 2020Aspirant
Hi Christian,
I have followed your instructions to upgrade it to the latest firmware V1.0.2.76_1.0.35. It worked for 2 days, then the network starts crashing again (more seriously...). I even tried factory reset. It's not working well. Upgrading or downgrading the firmware helps maintain a stable network environment for about 2 days. My network consists of a laptop device with Intel AX200 and a Galaxy Note 10+ with a WiFi AX chip. Please let me know if you need more information. Thanks!
