thomasyim02
Mar 14, 2020Aspirant
Network crashes after upgrading my Galaxy Note 10+ to Android 10
Recently, I upgraded my Samsung Galaxy Note 10+ to Android 10. I discovered that the network connection between my smartphone and RAX80 is unstable. Then I searched related issue on Google and found ...
thomasyim02
Mar 22, 2020Aspirant
Hi Christian,
I have tried QoS and Smart Connect. Either turned it on or off does not have any improvement regarding to this compatibility issue.
BR,
Thomas
Christian_R
Mar 24, 2020NETGEAR Employee Retired
Hi Thomas,
We recently released a new firmware version. May you check to see if there is a firmware update using the Nighthawk app or web interface.
Thanks,
Christian
- thomasyim02Mar 30, 2020Aspirant
Hi Christian,
I have followed your instructions to upgrade it to the latest firmware V1.0.2.76_1.0.35. It worked for 2 days, then the network starts crashing again (more seriously...). I even tried factory reset. It's not working well. Upgrading or downgrading the firmware helps maintain a stable network environment for about 2 days. My network consists of a laptop device with Intel AX200 and a Galaxy Note 10+ with a WiFi AX chip. Please let me know if you need more information. Thanks!
- Christian_RApr 01, 2020NETGEAR Employee Retired
Hello thomasyim02,
Thanks for confirming. I'd like for our support team to reach out to you for further assistance. If you're interested, please send me a private message with your contact info and serial number.
Christian
- thomasyim02May 04, 2020Aspirant
Hi Christian,
I have sent you a private message.
Thanks,
Thomas Yim
